Bore interpolation circularity - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: Bore interpolation circularity
  1. #21
    Sep 2007
    If the service guy came, he would probably do a ballbar test. Some service guys have a great understanding of machining, clamping, programming etc, but many don't. It's not their fault, it's their background and training. I was repairing cncs (electronics) before I could even start the spindle turning.
  2. #22
    Nov 2008
    canada
    I have TM3 so not so ridged set up I get out of rounds wen setup is at far left table;center table way more accurate .
  3. #23
    Registered Wing Nut's Avatar
    Apr 2010
    Try writing a G13 program to see if you get the same results. It might be a MasterCAM problem and not the machine.
  4. #24
    Apr 2008
    Dougtyler might have your answer,
    We have been circle milling some pretty close sizes for many years with other companies we worked for, but in our new shop at the time haas VF2-SS would not cut round holes.
    We played and played with this one for quite some time trying this, trying that.
    Could not believe how out of round the hole dia's were!
    We ended up fixing problem with breaking up the arcs in quads, and not using the "R"s, instead we use the "I" and "J" and now the holes are very round within .0003 or better.
    Paul
