Need Help! Alarm # 123 Spindle Drive Fault - Page 3
Page 3 of 3 FirstFirst 123
Results 25 to 30 of 30
Thread: Alarm # 123 Spindle Drive Fault
  1. #25
    Jul 2017
    Sweden
    Default Re: Alarm # 123 Spindle Drive Fault
    Polillo,
    Thank you for your reply.
    Yes, we have checked everything(?) and it still won't work. The Vector Drive goes into Fault mode even without the 325V line connected, so we suspect there's still something wrong with it that wasn't discovered during the repair. So we're in the process of sending it back to the repair center in Germany for another check.
    Best Regards,
    Gyro_Gearloose
  2. #26
    Feb 2018
    Mexico
    Dear Gyro_Gearloose
    if the alarm is 123 drive spindle fault and energy regenerative the problem this in control tage not in source power
    in the power stage do not problem
    the problem this in control stage normaly in source conmuted has several small circuits that make the control in vectorial unit
    i suggest check the control stage in my case there i found problem. is necesary check all elements one to one and be doing tests for detected wich elements failling.
    you can feed the power unit stage whit a transformer to test this for check elements, do not for check output of the vector this can only on the machine unless you can simulate machine outside for test.
    I hope this helps with your problem
    regards
  3. #27
    Jul 2017
    Sweden
    So far, so good.
    Last Friday I opened all four servo amplifiers for a visual check. I found that one of them had two blown capacitors and another had capacitors with signs of high internal pressure. Being a careful man, I ordered new capacitors and thermal pads for all four amps and desoldered all 24 IGBTs to test them separately. They all tested OK so when the new components arrived yesterday I assembled everything and tested the circuit boards again. Almost as on que, the Vector Drive came back from Germany today with a new 25W pre-charge resistor for the 325V line (The old one had burned, causing the previous problem). I proceeded to install all components in the machine but tested the Vector Drive "alone" first, without anything connected to the 325V line. Now the big capacitors inside the VD charged up fine and the Fault LED went dark after a few seconds.
    Switching off the machine again and waiting for the HV to bleed off, I connected one servo amplifier at a time and restarted to see if anything would go boom.
    It didn't.
    Instead the amps came up with green LEDs one by one and the machine started up accordingly when all amplifiers were connected, without any nasty error messages! It was a darn good feeling when I could execute the "S500 M3" commands and hear the spindle starting! All axis are also moving accordingly so the amplifiers are OK too. I did, however, encounter an error message (Spindle drive fault) when stopping the spindle, where it took "forever" to slow down and stop. Most probably (hopefully!) this is caused by changing/disabling the spindle retardation parameter, this was done as a part of the initial troubleshooting and never set back to where/what it was initially. I'll take a looksee at that tomorrow. If the problem persists I'll replace the Regen IGBT again, just to be sure...
    And yes, the low voltage power supply I mentioned earlier is also fed from the 325V line, I found out when I ripped out the servo amps. This PSU feeds them with +/-12V.
    So that's the situation at the moment. Although "It ain't over until the fat lady sings", I can see this machine back in production after Easter. May I not be proven wrong.
    Best regards,
    Gyro_Gearloose
  4. #28
    Jul 2017
    Sweden
    Hah, was I ever proven wrong!
    With orders and production volumes up in the skies, I haven't had time to do anything more with that machine until a couple of weeks ago. But finally I had some "spare" time to give our mill a little TLC. When checking, I found the main source for the problems; the Regen resistor pack had developed a break in the circuit! Probably all these years in service, heat and lots of vibrations finally killed two of the resistors. It all worked fine when the resistors were cold, but a crack in the resistive material opened up when they got warm, and then there just wasn't any regen anymore! Without the regen resistor, the bus voltage soars to well over 600V (reading went off the scale of my trusty old multimeter) and BOOM! - regardless of new VDRs in the 325V line. (Yea, I replaced those as well when I took care of the servo amplifiers.)
    But, I ordered a bunch of components; resistors, opto isolators and a new IGBT and replaced the whole shebang in the HV/Regen circuit w/o taking more time to troubleshoot. I also rebuilt the Regen resistor pack with new components and mounted a 12V fan inside it, fed from the AT PSU.
    Imagine my happydance when I first started the spindle on 500 RPM and then stopped it without any errors!!!
    Continuing to test with increaasing RPMs shows that that porion of the machine now is working accordingly.
    So now I've taken on a new part of this restoration, elliminating the nasty crunchy sound that the driveline makes when running on 800RPMs and above. So far I've split the motor/gearbox and sent the motor to Finland for bearing replacement. At least the drive side bearing in the motor is shot. The primary gear is probably heat-shrunk onto the motor axle and there was no-one in this city that could get it off. Tornion Sähköpojat (Electro-boys in Tornio) has specialized in this kind of work so it should be a walk in the park for them to replace the bearings.
    There is a grease cerk on the motor's end bell, but who the heck can imagine it's there, when it's hidden by two covers? I'll also replace all bearings in the gearbox and also replace the tachometer driveline: The tacho drivebelt is reduced to just a rag and the drivewheel coming out from the gearbox is severely worn down. I'll contact our local Haas distributor on Monday and ask for replacements, if they - as usual - don't have any other solution than to replace the entire motor/gearbox assembly (which will cost a bloomin' fortune!) I'll contact one of my former schools and ask them to make a new drivewheel for me. Will probably cost us a cake or two instead of around $4000... I know they have the drivebelt but I didn't see the wear on the drivewheel when I spoke with their tech so it wasn't mentioned.
    But now I see an end to this project, now my hope is that the machine will be back in service before the end of 2018, or at least in the very beginning of 2019. Do NOT wish me luck!
    Best regards,
    Gyro_Gearloose
  5. #29
    *Registered User* Cojaq's Avatar
    Jan 2019
    "I also downloaded Tayfunk's circuit diagram of the VD, it helped me a lot when doing the initial troubleshooting, Thanks a bunch, Tayfunk!"
    Hello Gearloose, I'm wondering if I could get the diagram of the VD from you?
    I have been having intermittent issues with alarm 123 spindle drive fault. Nothing serious YET! I would like to avoid a complete shutdown if at all possible. I have read on numerous forums that this is a common occurrence, but no one seems to have a clear reason and surefire fix for this. I would prefer it if I didn't have to replace a bunch of unnecessary items. Most all of my measurements have been within the prescribed ranges for the items that are in the power and control loops. I don't know what else to check that has not been discussed and therefore I would like a diagram of any and all associated circuits. Thanks for any help.
  6. #30
    Jan 2019
