- Check if program has run before (~1000 unique jobs, accidental reruns)
In my shop I have several NGC machines reading programs from a network locations. We produce around 100 unique pieces a day and sometimes have operators run the same file twice.
Is there any way to have a M or G code self edit the file? For example, at the end or the program, edit itself with a cycle count number?
I know I can do this with loop counters respective the machine but does not solve if an operator runs it on a second machine.
I log to a DPRINT file, but not sure if I can check DPRNT for a string of text before continuing.
Any ideas?
- You may not post replies
- You may not edit your posts
Forum Rules
