Haas UMC1000 MRZP problem
Results 1 to 1 of 1
Thread: Haas UMC1000 MRZP problem
    Member MrErikk's Avatar
    Feb 2019
    Default Haas UMC1000 MRZP problem
    We have Haas UMC1000 about 6 months old. No carashes and geometry is perfet.
    When the tabel is B0 C0 everything is okei but when we rotate B90. it cuts pocket to wrong position 0,3mm along x axis.
    Setting 255, 256, 257 are correct otherwise other dimensions should be wrong.
    If i change setting 257 0,3mm so that the pocket location is correct, then the pocket depth is wrong 0,3mm. If i change it 0,15mm pocket loacation is wrong and depth is wrong by 0,15mm
    MRZP calibration did't help, WIPS calibration and MRZP calibration - have done this many times, no help.
    Used this toubleshoot to fix / get idea how to fix. : https://www.haascnc.com/service/trou...--ad05450.html
    Attached Thumbnails Attached Thumbnails Haas UMC1000 MRZP problem-mrzp-1-jpg
