I've been having a problem with my DM-2 not orientating following a lower RPM tapping operation, but today I had it do the same thing on a drilling operation where my RPM was only 600 rpm.
What happens is the spindle doesn't orientate and then it does a tool change the tool drops because the spindle isn't orientated.
I had already posted this issue a few weeks ago, but now that it appears it has more to do with the RPM verses the tapping operation I figured I would create a fresh new post.
I'm guessing there must be a parameter setting that's causing it not to orientate on a low RPM ?
I don't know what the breaking point is as far as how low the RPM needs to be for this to happen, but I just tried the drilling operation with an RPM of 1,000 and it worked fine..... ( so it must be any RPM lower than that )
Any thoughts or suggestions ?
Thanks,
Kent
I was just using a chamfer tool to go strait down into a hole I had drilled to create a cutout for a screw head.
I realize now that the RPM was too low for this operation.
The machine works flawlessly on all of the tool changes, but only has issues on these low RPM situations.
I will fix that by making sure I don't put in a low RPM going forward.... but it would be nice to figure out whats causing this glitch.
I called my local haas dealer when this first popped up on a tapping operation ( also at low RPM ) and he had me add a couple of lines of code after the tapping operation that forced the machine to change RPM's before the tool change and the fixed the issue.
he asked me what version of software I had and he made the comment " that should have been fixed with that version " which left me with the impression that it's a known issue software glitch.
This is the line of code he had me add at the end of the tapping operation that "temporarily" fixed the issue
S100 M3
G4 P500
Where it got left was that we were going to have the software reloaded in the machine.... but now after running into this today with a simple drilling operation I'm thinking it may be a parameter setting.
Like I say, I will just make sure all of my RPM's are at least 1,000 going forward and that will fix the issue.
Mactec54
