- Tool holder drops after doing tapping operation
I have rigid tapping on my super mini mill and it's worked flawlessly.
The super mini mill has an umbrella style tool holder.
Recently I purchased a Haas DM-2 that has the side mount tool holder.
The tool changer has worked with no issues.
Today I did my first tapping operation on the DM-2 ( it also has the rigid tapping feature )
The tapping portion worked, but when it went to change to the next tool, the tool holder fell on the table, and the next tool didn't load properly because I'm guessing the notches were not lined up correctly.
I am using Fusion for creating my code, and I used the same post processor as I have used for the super mini mill.
I'm wondering if I don't need a spindle orient line at the end of the tapping operation to get the cogs in the spindle lined up before the tool change?
Or is there a parameter setting that needs to be changed to make this happen after all tapping operations?
Like I said before, the tool changer has been working perfectly, so I think it has something to do with the tapping operation that left the cogs not lined up correctly.
Any thoughts or suggestions would be appreciated...
Here is the code from the tapping operation.
(Tapping Operation)
N105 M9
N110 M1
N115 T40 M6
(T4)
N120 S500 M3
N125 G154 P1
N130 M8
N135 G0 X1.75 Y-1.8332
N140 G43 Z0.6 H40
N145 T35
N150 G0 Z0.25
N155 G99 G84 X1.75 Y-1.8332 Z-0.1 R0.25 F25.
N160 X1.75 Z-0.25
N165 X1.75 Z-0.4
N170 X1.75 Z-0.55
N175 X1.75 Z-0.7
N180 G98 X1.75 Z-0.8
N185 G80
N190 G1 X7.875 Z0.25 F500.
N195 G99 G84 X7.875 Y-1.8332 Z-0.1 R0.25 F25.
N200 X7.875 Z-0.25
N205 X7.875 Z-0.4
N210 X7.875 Z-0.55
N215 X7.875 Z-0.7
N220 G98 X7.875 Z-0.8
N225 G80
N230 G0 Z0.6
N235 M5
(Drilling Operation)
N240 M9
N245 M1
N250 T35 M6
(CS9)
N255 S600 M3
N260 G154 P1
N265 M8
N270 G0 X1.75 Y-1.8332
N275 G43 Z0.6 H35
N280 T33
N285 G0 Z0.25
N290 G98 G83 X1.75 Y-1.8332 Z-0.29 R0.25 Q0.05 F6.
N295 X7.875
N300 G80
N305 G0 Z0.6
N310 M5
N315 M9
N320 M33
N325 X4.8125
N330 G53 G0 Y0.
N335 M30
- You may not post replies
- You may not edit your posts
Forum Rules
