Having problems with my new Scroll air Compressor - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
Thread: Having problems with my new Scroll air Compressor
  1. #21
    May 2013
    Default Re: Having problems with my new Scroll air Compressor
    It's been a long process trying to get this compressor working correctly, but its finally working great!
    I added a Acme Electric model A3015K0310B transformer ( Buck Boost Transformer ) to help get my voltage set closer to the safe voltage that the compressor was looking for.
    The transformer ran around $600
    I contacted the manufacture of the transformer and they gave me the correct wiring configuration to get our output voltage at aprx 234v
    There are various wires inside the transformer and depending on how they are hooked up with get you to the desired voltage. ( the wiring configuration they gave me wasn't in the manual )
    You can either raise your voltage or lower it depending on what wires you use on the inside.
    This has now solved the issue of the over voltage alarms, and it has also solved the issue of the contacts chattering when they engage.
    So we are good to go...
  2. #22
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by kentdesautel13 View Post
    It's been a little journey, but more expense than was needed though, once you had committed to the transformer, you had to make that work, it looks like the compressor is wired then for a 230v supply and NA 240v was just a little too much inrush for the cooling fan.
    Mactec54
