Change Tools in Middle of Program - How to?
Results 1 to 2 of 2
Thread: Change Tools in Middle of Program - How to?
    Jun 2008
    Default Change Tools in Middle of Program - How to?
    I've got a program that requires eleven different tools, but the toolchanger in my Haas mill only holds ten. I don't want to have two separate programs and, since the program is long, I don't want to have to restart it from the beginning after the tool change. Is there a way to 'pause' the program while the tool change is made?
    May 2016
    Default Re: Change Tools in Middle of Program - How to?
    If your machine has a swing arm type tool changer you can use T0 as a tool call, and enter the T0 tool height in a spare H column. (I'm talking Fanuc, but isn't this the same on Haas?)
    If you have a Carousel type changer, then what about M00 Mandatory stop? Program two tools as if they each had a place in the carousel, use an arbitrary spare tool height offset for one of them, and put an M00 between each transition/tool change period.
