Good Afternoon,
I have a TL-2 Lathe that has a "Cycle Doors" message that will not clear. The top two limit switches have been verified back to the circuit board. If I disconnect the connector from the circuit board and meter between the red and black pins I can see ~1 ohm when the door is closed, and an open circuit when the door is open.
This message will not clear from the machine though. I am also not seeing any voltage on the door circuit, if I open the connection between the red and black closer to the limit switches and check for a potential difference I am seeing 0 volts. The circuit board is powered up though, I can see several green and red lights on it.
Any advice is appreciated, thank you.
