Need Help! 304 invalid I,J, OR K in G02 or G03
Results 1 to 5 of 5
Thread: 304 invalid I,J, OR K in G02 or G03
    Member Awbrey-p's Avatar
    Jan 2021
    Default 304 invalid I,J, OR K in G02 or G03
    I'm currently training in CNC Lathe but I'm running into an issue with the arch. I am currently on a Haas Simulator. My instructions were to use IJK but I'm struggling.
    Awbrey P
    Attached Thumbnails Attached Thumbnails 304 invalid I,J, OR K in G02 or G03-1611764216139680663278259133650-jpg
    Member machinehop5's Avatar
    Aug 2009
    Default Re: 304 invalid I,J, OR K in G02 or G03
    ...try using R for arc center. Read more about it below link
    https://www.haascnc.com/service/code...value=G03.html
    sip-
    The R-value defines the distance from the starting point to the center of the circle. Use a positive R-value for radii of 180 or less, and a negative R-value for radii more than 180.
    Feb 2011
    with out the information on the print it will be hard to give you the correct answer
    if the arc is being cut from .440 in the x axis to a smaller x value then back to the .440 dia.(G2)
    with the z axis starting at -.565 and finishing at -.940 your k value would be k-.1875
    Aug 2009
    ...sim report when fixed. Followup
    over vs under Newton's Law
    Jan 2021
    Thank you all for the suggestions but we just
    Split the arch into two partials and it worked
