HL-1 Spindle drive fault 123 / Overheat NEED HELP
Results 1 to 3 of 3
Thread: HL-1 Spindle drive fault 123 / Overheat NEED HELP
    Member kruminiepa's Avatar
    Oct 2019
    Default HL-1 Spindle drive fault 123 / Overheat NEED HELP
    Hello !
    We are having issues with our HL-1 / 1998
    We bought machine in august this year. We have not done a single good part on it, we solved multiple errors on the machine. since that, and the last and most important is left.
    At the moment we have two errors on the machine:
    Spindle motor overheat 254 (fan is working, motor cold), when we clear this error via parameter 274:14 next issue happens -> when we run a programm, and rpm are dropped fast Spindle drive fault 123 appears and spindle spins freely. (fans work)
    Oct 2019
    Default Re: HL-1 Spindle drive fault 123 / Overheat NEED HELP
    Video for insight
    Oct 2019
    FYI, problem was fixed.
    1) We sent Vector To germany, for refurbishment. 1200eur
    2) faulty WYE / DELTA unit
    all done
