We have a 2004 Haas SL30T lathe. It has a tool presetter set up on it. While setting the tool length you hold down the jog key and it moves the tool over to the presetter probe. Once it gets to the probe it leans the probe over a bit and beeps then sets the tool length of the tool. When it does this it stops the movement of the tool. Sometime back we had an issue where the machine would not beep and would just keep moving. I did some looking online and found a parameter or a setting that needed changed to fix this issue. Well it is now doing it again. I have been looking again for this information and for the life of me cant find it. Anyone have any ideas what the setting/parameter is I need to change?
