TL Lathe Tailstock Rigidity
Results 1 to 2 of 2
Thread: TL Lathe Tailstock Rigidity
    Jun 2005
    Default TL Lathe Tailstock Rigidity
    I have a TL-2 lathe with a side clamp style tailstock like the picture below.
    https://520machinery.com/2007HaasTL2_01232012-2.jpg
    It has a lot of deflection in it. I can push it by hand when locked so it deflects at the top by 0.002" or so. It also squeezes the rails together about 0.005" when clamping and obviously doesn't repeat well that way. I can machine anything over 24" long without major chatter at the end. Is this normal for this setup. I realize the design has clanged a few times over the years. Mine is a 2006.
    I am considering making a new base and use the Bosch bearing blocks, however I am wondering how much better that is? Or is it a lack of rigidity in the rails themselves? If anyone has a newer lathe with preloaded bearings in the tailstock I would love to know how ridged it is?
    Thank you in advance.
    Will
    Member Jim Dawson's Avatar
    Dec 2013
    Default Re: TL Lathe Tailstock Rigidity
    Looks like poor design to me. The entire mounting system does not provide much lateral support, hopefully the newer machines have a more robust design. The tailstock should be as rigid as the headstock.
    Jim Dawson
    Sandy, Oregon, USA
