Oring groove tool
Results 1 to 5 of 5
Thread: Oring groove tool
    Oct 2011
    us
    Default Oring groove tool
    I have been searching for a .125 oring groove tool to tun an oring groove on some stock . does anyone have any suggestions or part numbers for the holders and inserts . all of the tooling places I have talked to had no idea and kept telling me I need an end mill .
    Dec 2013
    Default Re: Oring groove tool
    For a lathe, grooving tool, like a parting tool. or just use a 0.125 wide parting tool.
    https://www.google.com/search?q=groo...w=1815&bih=952
    Jim Dawson
    Sandy, Oregon, USA
    Member Machineit's Avatar
    Mar 2010
    I think what you are looking for is something like in the picture below. This one is made by Valenite. The problem with these is that they are only good for one diameter of groove because the support section must match the groove. This one is for about a 2.5" diameter groove.
    Check with the major tool supplies like Valenite, but you might want to use a grooving tool with some taper on each side to clear after cutting.
    Good luck------Mike
    Attached Thumbnails Attached Thumbnails Oring groove tool-20181207_090448_resized-jpg
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
    Mar 2010
    Found this image and it is a Sandvik.
    Attached Thumbnails Attached Thumbnails Oring groove tool-z1snrvpcpex_-jpg
    Mar 2017
    Quote Originally Posted by billwann View Post
    you need a new tooling vendor
    and this thread needs more blueprints- with dimensions
Oring groove tool
Oring groove tool
