Hi All
I just had this error 622 c axis engagement come up the other morning. I've narrowed it down that it only does it when its cold. If i run the machine for a few hours on non c axis engagement parts, then it works just fine.
I'm assuming it might be a tolerance issue in the engagement cylinder assembly? The shops about 40-45F in the morning.
Has anybody else experienced this issue? What was the fix?
2014 ST25Y
Thank you
Bear
