MeshCam - how do I send the G-Code to the GRBL machine
Results 1 to 3 of 3
Thread: MeshCam - how do I send the G-Code to the GRBL machine
    Jun 2021
    Default MeshCam - how do I send the G-Code to the GRBL machine
    I'm prepared for this to be a stupid question but I've never done it before and it is missed in all the videos I've watched. They show how to use the software and then say.... Just send it to your machine.
    The CNC router came with instructions on how to setup and run Easel, which I have done and have progressed only as far as leveling my waste board.
    Do I send the G-Code to Easel or straight to the CNC controller. If straight to the machine how do I do the other setups like home, z axis, jogging, and start position.
    If I have to go through a management type program can I use an alternative to Easel that is not cloud based. I don't mind buying it but I want a perpetual licence.
    Member routalot's Avatar
    Dec 2003
    Default Re: MeshCam - how do I send the G-Code to the GRBL machine
    You don't provide much information about your machine and that makes it difficult to give a thorough answer.I'm guessing it is Arduino based and if so,you might be able to use Universal Gcode Sender.
    Jun 2021
    Quote Originally Posted by routalot View Post
    Thanks again.
    I just looked at UGS and it seems understandable to me. I'll run with that.
