Which plastics are hard and soft for Onsrud O-flute bits
Results 1 to 3 of 3
Thread: Which plastics are hard and soft for Onsrud O-flute bits
    Member scott216's Avatar
    Apr 2012
    Default Which plastics are hard and soft for Onsrud O-flute bits
    Onsrud has their O-flue design. Some bits say they are for hard plastic, some are for soft. I can't find anywhere where Onsrud defines what is hard and soft. Anyone know?
    --Scott
    "You can't teach stuff in a school that you would learn in real life unless the real life people are in charge of the school." - Gene Sherman
    Community Moderator difalkner's Avatar
    Nov 2014
    Default Re: Which plastics are hard and soft for Onsrud O-flute bits
    Cast acrylic machines easily but stay away from extruded. Extruded tends to melt but cast cuts like wood or aluminum.
    David
    Romans 3:23
    CurlyWoodShop - www.etsy.com/shop/CurlyWoodShop
    David Falkner - www.youtube.com/user/difalkner
    difalkner - www.instagram.com/difalkner
    Member Bob_Valentine's Avatar
    Feb 2021
    Both types of acrylic (Cast and Extruded), Polypropylene, Polycarbonate, anything with an epoxy resin, and Bakelite are some types of hard plastics (I recommend the spiral down cutter for the Bakelite, spiral up cutter for all others unless they are 1/8" thick or less).
    HDPE, LDPE, sintra, and "cutting board" plastic (not sure the exact name for this type of plastic) are considered soft plastics. I have had some good success running pretty quickly through both hard and soft plastics using the the hard plastic cutters from LMT Onsrud and Techno CNC Systems. Hope this is helpful.
