cutting 25mm clear acrylic
Results 1 to 2 of 2
Thread: cutting 25mm clear acrylic
    Apr 2016
    New Zealand
    Default cutting 25mm clear acrylic
    Good day
    I am trying to cut letters off 25mm clear acrylic using a CNC machi
    My bit is 6mm O- flute, new
    I tried 18k spindle speed, 5000 feed rate , 5 steps of 5mm deep each
    The bit gets hot , the plastic melts onto it
    I am wonder if some one can advise me
    Thank you in advance
    Nissim Cohen
    Default Re: cutting 25mm clear acrylic
    Hello,
    For me, making two cuts per depth have helped. With stepover of 0,2mm
    Hautamak
