machining acrylic
Results 1 to 3 of 3
Thread: machining acrylic
    Member teamloks1's Avatar
    Feb 2019
    Default machining acrylic
    Hello just want to ask question regarding edge finishing i already tried many bit most of it same or just a make a little difference from 1 flute hss to 3 flute onsrud carbide all
    here the picture of machine i think it rigid enough to cut acrylic
    using servo motor with 4.5 kw bt30 atc spindle i already test the runout of my spindle its around 0.004mm and im using sk tool holder with 0.002mm runout
    those mark i cant even feel it when i touch only can see it by diff angle mostly i cut w ith 18000 rpm 60ipm
    Attached Thumbnails Attached Thumbnails machining acrylic-photo_2019-10-10_18-42-50-jpg   machining acrylic-photo_2019-06-03_19-49-29-jpg   machining acrylic-photo_2019-06-03_19-49-28-jpg   machining acrylic-photo_2019-10-10_18-42-50-2-jpg
    machining acrylic-photo_2019-10-10_18-42-50-3-jpg
    Mar 2003
    Shelby Township
    Default Re: machining acrylic
    It's most likely due to flex in your machine.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
    Feb 2019
    Quote Originally Posted by ger21 View Post
    im taking finishing pass with 0.25mm left even with 3mm thickness got this mark is it because of flex?
machining acrylic
machining acrylic
machining acrylic
