Machining PTFE 25% glass
Results 1 to 4 of 4
Thread: Machining PTFE 25% glass
    Member FabricioP10's Avatar
    Aug 2019
    Default Machining PTFE 25% glass
    I never worked with this material first time..I have +/.005 on everything..My problem is the material shrinking on the OAL bringing lineara out of tolerance as well but my diameters stay the same..How can I fix that issue??..I’m not familiar working with this material but I’m willing to learn it..I’m running it on a 28”l doosan..I have sharp radius inserts to rough and finish and I’m using a .062 part off iscar..Any ideas on how I can resolve the issue
    CJR1985's Avatar
    Aug 2019
    Are you sticking material out and running multiple parts or a single part program?
    Aug 2019
    I’m running it as part off..running multiple parts from a 12 inch plastic tuberculosis
    Member awerby's Avatar
    Apr 2004
    Default Re: Machining PTFE 25% glass
    Quote Originally Posted by FabricioP10 View Post
    That certainly sounds dangerous! Wear a surgical mask, and use disinfectant as coolant...
