12mm Porcelain Slab advice
Results 1 to 2 of 2
Thread: 12mm Porcelain Slab advice
    *Registered User* dankiop72's Avatar
    Jun 2018
    Default 12mm Porcelain Slab advice
    Porcelain slabs are very new to the industry, so i thought i'd ask ANYONE out there if they could help me.
    Looking at getting a second-hand CNC (Zeus - 3-axis CNC), for a steal!
    Wondering if its possible to cut 12mm porcelain slabs with a router bit instead of purchasing a separate saw????
    Apr 2004
    Oakland CA USA
    Default Re: 12mm Porcelain Slab advice
    Stick with the saw, if you're making straight cuts. The only reason to use a router would be to make fancy cuts a saw couldn't do. But it would be a lot slower.
    Andrew Werby
    https://computersculpture.com/
