No, a laser won't do anything like that. A wood router won't either. You'd need a specialized machine like one of these: https://www.besana-usa.com/product/l...bevelleredgers .
hi there
I have a question on cutting glass, attached are the pictures of the Glass that I want to cut using a CNC machine.
My question is as follow can a Leaser CNC machine Cut these Items, I do not have any experience on leaser machines.
If it was a Wood Router, I know How to cut Items like these, but with leaser machine I need help.
if I could, what software do you recommend?
As a general rule, I know I can cut, and engrave with Leaser CNC, But is a 3d or relife sort of procedure a
possibility with Leaser CNCs? I guess it is, any explanation is greatly appreciated.
I should mention that the glass thickness in the pictures that I need to cut range from 4 mm to 16 mm
Regards
Jhonansaro
