OMAG Mill98 / NUM 1040 System SRAM issue
Results 1 to 5 of 5
Thread: OMAG Mill98 / NUM 1040 System SRAM issue
    Jun 2016
    Default OMAG Mill98 / NUM 1040 System SRAM issue
    Good afternoon all, I'm taking a shot at getting an answer for this, but, I have an OMAG Mill98 with a NUM1040 controller that I'm having an issue with. It's giving me the following error message on powerup:
    error found on SYSTEM RAM header's checksum !!!
    checksum found = 00014040, checksum obtained = 00044F4E
    pointer's SYSTEM RAM obtained = 7B6FBF5F 0F100503 53EFFFFF 9D010A04 00104040 FFFFFFFA
    Ready to clear Systeme SRAM ? (Press any key to continue) :
    http://www.cnczone.com/forums/attach...d=325188&stc=1
    If I press any key on the control, it tells me wrong answer, please retry.
    Any clue what's up here? Are the RAM modules no good?
    Attached Thumbnails Attached Thumbnails OMAG Mill98 / NUM 1040 System SRAM issue-img_0915-jpg
    Jun 2016
    Default Re: OMAG Mill98 / NUM 1040 System SRAM issue
    The first line was missing, because I had tried to press "any key" to proceed. It says "global reprom programs execution"
    Sep 2016
    United Kingdom
    Hi. This is a "simple" one
    The RAM modules are probably perfectly OK. The problem is that your battery has failed.
    You need to replace the battery 0297900000 and then re-load the backup from your archive... Hopefully you have a backup, if not you will just need to contact OMAG and give them your machine serial number and affaire number of the CNC
    Sep 2016
    United Kingdom
    Oh, and you have to answer with either Y for yes or O for yes in French
    Mar 2014
    Hello!
    Finaly how do you solved the problem?
    .... because I have same problem!!!:<
    Best regards,
    Traian.
    Same here, any help would be apreciated. I know i have to replace the batteries, my question is, how do i reload backups if the machine doesnt boot?
