My DIY Stone Bridge Saw
Page 1 of 3 123 LastLast
Results 1 to 20 of 47
Thread: My DIY Stone Bridge Saw
    Registered DennisCNC's Avatar
    Aug 2005
    Default My DIY Stone Bridge Saw
    Here are some pics of the saw that my Dad and I built.
    Travel is 14x14 feet, spindle is 10HP, X Y drive motors are 3ph 1.5HP, the Z motor is a 1HP DC with brake. The table lifts up and rotates.
    Before this we were cutting with a rail saw,,,not fun.
    Still working on the covers for the THK rails......
    Attached Thumbnails Attached Thumbnails My DIY Stone Bridge Saw-allfront-jpg   My DIY Stone Bridge Saw-controlboxes-jpg   My DIY Stone Bridge Saw-controlinside-jpg   My DIY Stone Bridge Saw-controlpanel-jpg
    My DIY Stone Bridge Saw-frontcutting-jpg   My DIY Stone Bridge Saw-overall-jpg
    Dennis
    Banned diarmaid's Avatar
    Apr 2006
    Alaska
    Very Cool. One hell of a diy! Congrats on the (near) completion.
    Dec 2004
    Barbados
    wow!
    Jason
    Mar 2004
    Sweden
    That's really awsome! Do you have any picture on a ready piece?
    Aug 2005
    ^^ Do you mean, stone that was cut on the saw? I'll take some pics tomarrow. But the edges are razor sharp and does not chip the buttom or cross cut corners. We used a rail saw like the Blue Ripper before this and this thing makes wayyyy nicer cuts.
    I'm felling a CNC next for the sink holes that every one, very dislikes doing.
    Dennis
    Mar 2005
    Toronto, Canada
    nice work, any build pictures or detail pics, ie frame, linear motion set up etc?
  7. #7
    Aug 2005
    Here are some pictures of the bridge and Z axis and a few others. The big THK's are SR85 and rated at 37,000lb each block, I know it was thousand time over kill but they were available for a good price. The Z axis has a rotating nut ball screw and two SR20 rails with six blocks. The steel plate is 1" thick. We used a chain for the drive system because it was a easy alternative to other methods and we don't need positioning accuracy as with CNC. Everything turned out excellent. There are limit switches on all axis as I found that the motors will rip the chain like nothing if the bump stop is hit. The chain is iso 40 rated at 4,000lb. There is a green line laser to help with positioning the cut. The blade is a silent core 16".
    Attached Thumbnails Attached Thumbnails My DIY Stone Bridge Saw-bridge-jpg   My DIY Stone Bridge Saw-pump-jpg   My DIY Stone Bridge Saw-zaxis-jpg   My DIY Stone Bridge Saw-side-jpg
    My DIY Stone Bridge Saw-side2-jpg
    Dennis
  8. #8
    Mar 2005
    Toronto, Canada
    thanks for details, what a beast!
  9. #9
    Apr 2006
    Alaska
    wow!!
  10. #10
    Member Halfnutz's Avatar
    Feb 2005
    Very impressive!
    Halfnutz
  11. #11
    Apr 2006
    Alaska
    Is there a coolant supply for while cutting?
  12. #12
    Aug 2005
    ^^ Yeah, there is a 3hp water pump pumping 250 gal of water every 30 minutes. The water gets cleaned and recycled.
    It's pretty fun cutting with this thing
    Dennis
  13. #13
    Aug 2006
    Very nice! It certainly looks like a hugh improvement over the rail saw!
    Kevin Emery Jr
    GMR Quality Stone Products
    gmrtools@charter.net
    c: 248-867-9875
  14. #14
    Jun 2005
    Any pics of the rotary table, I am building a brige saw also and am having a hard time coming up with the design of the rotary
    Thanks in advance
  15. #15
    Aug 2005
    The table was a hard one, so we found a rotating base from a man-lift and used that. We were thinking for a long while on how to make it raise up a rotate. I'll make some pictures tomarrow.
    Dennis
  16. #16
    Aug 2005
    Here are some pictures of the table up, the blue rams on both side are attached manualy to the table with the nuts on both side, it's a low tech way but works. My head was getting big from thinking to much on how to make the rams under the table.
    Attached Thumbnails Attached Thumbnails My DIY Stone Bridge Saw-sawtable-jpg   My DIY Stone Bridge Saw-sawtable2-jpg   My DIY Stone Bridge Saw-sawtable3-jpg
    Dennis
  17. #17
    Dec 2006
    Default Hey DennisCNC,
    Hey DennisCNC,
    Where are you guys located? I'd love to talk with you someday on the subject of building machines. Can I give you a call sometime?
    Robert
    336-364-1561
    www.robertmihaly.com
  18. #18
    Aug 2005
    Default DRO Upgrade
    I added a DRO on the Y axis, here are some pics. Still working on how to mount the display an easy way.
    Attached Thumbnails Attached Thumbnails My DIY Stone Bridge Saw-drobolt-jpg   My DIY Stone Bridge Saw-droshafttread-jpg   My DIY Stone Bridge Saw-encoderbolt-jpg   My DIY Stone Bridge Saw-encodermounted-jpg
    Dennis
  19. #19
    May 2003
    We need VIDEOS!!!
  20. #20
    Aug 2005
    My camera when snowboarding for a few weeks, so when it's back i'll make a video.
    Here is a pic of a 3 volt regulator that I needed to make for the Green line laser as it died after a week of use at 5 volts. They said it was 5 volts and latter told me it was a new model and needs 3 volts, but the company sent me a new one! It's a LM317 regulator.
    Attached Thumbnails Attached Thumbnails My DIY Stone Bridge Saw-regulator-3v-jpg
    Dennis
