Dinosaur skeleton, and other models, DXF files. - Page 27
Page 27 of 218 FirstFirst ... 17242526272829303777127 ... LastLast
Results 521 to 540 of 4351
Thread: Dinosaur skeleton, and other models, DXF files.
  1. #521
    Jan 2010
    Quote Originally Posted by jcoats View Post
    MontanaDave, if the slots are 3", I am guessing it was initially sized for 3mm slot sizes. Yes, changing units do seem to get in the way. And most of us are not good about noting what units we are typically using. ... Good looking Dino in the pix!
    Hello jcoats,
    That sounds like a fairly plausible explanation for that. All though I would tend to think that part of the information that dxf file carries would have to be what "units" it was drawn in.
    Dave
  2. #522
    Jan 2010
    Default Whale skeleton
    Gentlemen,
    One thing that's really caught my eye is the Blue Whale skeleton. I've looked at quite a few whale dxf files but they all seem to be for outlines of whales. I would like to build a whale "skeleton" similar to the way those dinosaur skeletons are built. Surprisingly (since whale hugging is so popular) I haven't even been able to find one of those small wooden commercialy made puzzles of a whale skeleton. If I had one of those I'd at least have a starting point to try and work up a dxf file to cut the pieces from.
    Has any one here ever come across a whale "skeleton" file?
    Thanks.
    Dave
    Attached Thumbnails Attached Thumbnails Dinosaur skeleton, and other models, DXF files.-blue_whale_skeleton_opt600x289_wikimedia-jpg
  3. #523
    Member bigz1's Avatar
    Apr 2006
    NZ
    Quote Originally Posted by MontanaDave View Post
    Gentlemen,
    Thanks.
    Dave
    I have scoured the net for 3D puzzles and I haven't seen a blue whale skeleton. But it dosn't look that difficult to make your own. 2/3 are 2 basic shapes which can be scaled and stretched. Each bone in the head could be done as multiple parts to make them curve(like the pteradons wings), same for the fins.
    Mines progressing well.Looking to test the joints for the wheels this weekend. Also considering putting a motor in it.
    Good luck
    Liam
    Attached Thumbnails Attached Thumbnails Dinosaur skeleton, and other models, DXF files.-jinty-jpg
  4. #524
    Jan 2010
    Quote Originally Posted by bigz1 View Post
    Good luck
    Liam
    Liam,
    Looks like the details on your train drawing are filling in nicely. Looking forward to seeing it built.
    Dave
  5. #525
    Apr 2006
    NZ
    Default JINTY DOWNLOAD PART 1
    Here is the DXF for the Jinty. It has been put through a thourgh test by my boys. Pictured is the MK1 version after a day with them. DXF is MK2 and has been tested. Its a standard 0-6-0 so could be used as base for other designs. A few points to watch out for build the wheels one side. Thread on the sides to the axles followed by the wheels on the other side. Conrods to go on last, but make sure you get them the right way round as axles are not equally spaced.
    When this push along version is finished I am looking to add a motor.
    No glue is required. The conrod is the only item to have a pocket on finished train.
    Attached Thumbnails Attached Thumbnails Dinosaur skeleton, and other models, DXF files.-w1-jpg   Dinosaur skeleton, and other models, DXF files.-w2-jpg
    Attached Files Attached Files
  6. #526
    Feb 2007
    Default alligator
    I am looking for an alligator skeleton puzzle dxf.
  7. #527
    Jan 2010
    Liam,
    Look'n good man. Great detail. Kind of makes me wish I was a wood worker instead of a torturer of innocent metal.
    Dave
  8. #528
    Dec 2004
    Memphis, TN
    Wow, that looks great!
  9. #529
    Mar 2008
    Norway
    What thickness of MDF is used for this model?
  10. #530
    Apr 2006
    NZ
    Quote Originally Posted by Odeott View Post
    Its 4.75mm. But it can be scaled up. To cut below this thickness you would need to scale down the cutter. I used a 1/8" bit. 6mm or 1/4" sheet would also be fine with a 3mm or 1/8" cutter.
  11. #531
    Nov 2009
    brasil
    ola alguem tem uma dxf de um relogio?
    obrigado
    celia
  12. #532
    Apr 2006
    NZ
    Quote Originally Posted by davek View Post
    Hope this helps.
    Attached Thumbnails Attached Thumbnails Dinosaur skeleton, and other models, DXF files.-alligator-2-bmp   Dinosaur skeleton, and other models, DXF files.-alligatorz-jpg   Dinosaur skeleton, and other models, DXF files.-alligator-1z-jpg
  13. #533
    Dec 2004
    Memphis, TN
    I used 3/16" hardboard. It's awful stuff but they don't have MDF that thin either at Lowes or Home Depot. The 6 "washers" do they go behind the wheels between the wheel and chassis?
  14. #534
    Apr 2006
    NZ
    Quote Originally Posted by Jay C View Post
    Yep the washers go between the wheels and the outside of the chassis. The DXF can be scaled up. Going smaller its essential to keep the router bit proportional. Otherwise fit might be too tight.
  15. #535
    Sep 2009
    Argentina
    Default Victorian House
    Hello Everybody, anybody have something similar like these to do?
    Dinosaur skeleton, and other models, DXF files.-kit-2-victorian-house-furniture-jpg
    Dinosaur skeleton, and other models, DXF files.-img_5281-jpg
    Dinosaur skeleton, and other models, DXF files.-kit-1-three-story-doll-house-furniture
    Thank you in advance
  16. #536
    Nov 2009
    brasil
    ola alguem tem uma dxf destes
    agradeço muito
    celia
    Attached Thumbnails Attached Thumbnails Dinosaur skeleton, and other models, DXF files.-escaravelo-jpg
  17. #537
    Nov 2009
    brasil
    alguem tem uma dxf destes ou parecido?
    agradeço
    celia
    Attached Thumbnails Attached Thumbnails Dinosaur skeleton, and other models, DXF files.-moto_cross-jpg
  18. #538
    Jan 2010
    Default Does anyone have dxf files for any of these?
    Does anyone have dxf files for any of these? (carp, Harley Davidson, revolver, pirate ship)
  19. #539
    Nov 2009
    brasil
    [QUOTE = johnmichael; 732744] [B] Alguém tem DXF para qualquer um desses? [/ B] carpa (, Harley Davidson, revólver, navio pirata)
    [IMG] http://www.3d-puzzle-toy.com/data_qx...1235580816.jpg [/ IMG] [IMG] http://www.3d-puzzle-toy.com/data_qx/upload / honor/20092181219261487.jpg [/ IMG] [IMG] http://www.3d-puzzle-toy.com/data_qx...5325867569.jpg [/ IMG] [IMG] http://www.ecclecstacy .com / Puzzle / pirateboat.jpg [/ IMG] [/ QUOTE]
    amigo vamos trocar umas dxf tenho todas essas que vc mostrou na foto quais voce me oferece e eu te passo essas
    aguardando
    celia
  20. #540
    Jun 2005
    the Netherlands
    Great Train Bigz,
    The Jinty is comin up good, we keep an eye on you
    Greetz Juan
