No, not really. I make circuit boards with my machine, and I too use double sided tape to hold it down. In addition I drill two 1.5mm diameter holes through the PCB blankI used double sided tape to hold down a project, and one of the small cutouts came loose and caused lost steps for all axis. Is there a good way to align the X and Y axis to the partially completed project after homing all axis and resetting the z0?
into the spoil board underneath and install two short 1.5mm pins. I make two sided boards and these pins allow you to flip the board and do the bottom side in perfect alignment.
These pins also mean that should you lose reference part way through the job that you can use the known location of the pins to reset your machine.
When I may a PCB I always have one pin at (0,-5mm) in X any Y and I can always use the center of that pin to reset my machine if required.
Craig
