Hi Kolias- What is the power and max rpm of the spindle? Peter
according to the chart attached the chipload should be around 0.0055" say 0.006" which for me is 0.14mm. Your chipload is CL=feed/RPM/N 30/5000/2= 0.003" (0.076mm) which is small so the tool does not have enough bite on the material so will just skid blunting the tool. So your about half the chart value so double your speed to 60in/min or go to 2500rpm or use a 1F tool. If the spindle has enough power it should do a 1/8" DOC. This also is based upon the spindle/machine is stiff enough.... Keep the tool short I have broken a few 1/8" tools because of long set tools.... Peter
