Basswood for cutting board?
Results 1 to 3 of 3
Thread: Basswood for cutting board?
    Member Denialxa's Avatar
    Sep 2022
    Default Basswood for cutting board?
    I found a great deal on Basswood panels at a local lumberyard. Can I make cutting boards out of it? I know they are primarily used for sculpting and carving but technically it is a hardwood. So going back and forth to try it out.
    Any suggestions would be helpful.
    Member awerby's Avatar
    Apr 2004
    Default Re: Basswood for cutting board?
    Are you talking about a board for cutting food on? No; basswood would be a poor choice for that, because it's so soft, with loose fibers. The distinction between hardwoods and softwoods has nothing to do with hardness; it's about whether the tree makes a different kind of wood in summer than in winter. For example, balsa wood is a hardwood, but it's very soft and light. Douglas fir is a softwood, but it's fairly hard (especially the old growth, with less space between the rings). Try "rock" maple, which is a hard hardwood. Use the basswood for something else.
    Banned
    Nov 2021
    I use basswood often for accent strips, because of the nondescript grain. You can cut it "any old way", and sometimes come up with some iridescence.
    I heat bend often in builds, and I'm still learning. I'm building a hull with pawlonia, and found that it responds to heat bending BETTER than cedar, which came as a surprise. I sense that it has a very low lignin content, and I had thought that woods with a higher lignin content would respond better. Maybe I'm heating up the lignin faster in this low-density wood.
