Need Help! please help regarding finishing quality milling wood
Results 1 to 6 of 6
Thread: please help regarding finishing quality milling wood
    Member PhilipTheArab's Avatar
    Mar 2021
    Default please help regarding finishing quality milling wood
    Good day
    Please see photo
    I used end mill 3mm for finishing
    feed rate 25mm/sec
    step over is 30%
    spindle speed 8000 rpm
    depth of the cut 8mm
    stock thickness 18 mm
    There are 2 issues as you can see in the photo
    1-You can see the half circules (like if the bit is drilling holes not milling) along the neck line.
    2-the second issue is the bit stroke lines like strips. I think this has to do with the spindle vertical alignment (Not sure because the alignment looks fine).
    Philip
    Attached Thumbnails Attached Thumbnails please help regarding finishing quality milling wood-engraving-issue-jpg
    Member awerby's Avatar
    Apr 2004
    Default Re: please help regarding finishing quality milling wood
    You're seeing those parallel lines because your step-over is so coarse. 30% is fine for a roughing pass, but not for the final one. Reduce it to something like 1/20th of the diameter of your tool and it will be a lot smoother.
    Mar 2021
    I will give it a try
    Thanks for taking the time to help
    Philip
    Member routalot's Avatar
    Dec 2003
    I don't know what software is being used but some programs will allow you to define boundaries and this allows you to use a larger tool for the areas with less sharply defined detail and confine the smaller tools to the nooks and crannies.It could save a lot of time as well as giving a better finish on the more gently curved areas.The direction of cuts may be specified to refine the finish in some areas also.If your software allows such a thing.
    Mar 2021
    I am using carveco/artcam for toolpath generation and linuxcnc for control. Blender and fusion360 for 3d.
    I thought the same as you mentioned, and I am trying to experement with artcam settings. For instance I could use helical toolpath instead of raster, and will play with ramping angles and other settings.
    Firstly I will reduce the stepover and/or use smaller diameter tool.
    Philip
    Mar 2021
    Quote Originally Posted by awerby View Post
    yes
    I went down with the step over to 10% of the bit diameter and the result is perfect
    I did not blow the dust yet, I will be engaged in other matters for few days, but I wanted to report the result before I go.
    Many thanks to you all
    Philip
    Attached Thumbnails Attached Thumbnails please help regarding finishing quality milling wood-head-reduced-jpg
  7. #7
    nolancharles's Avatar
    Dec 2022
    In 2015, Gluons Technology Company began its adventure with a variety of automation devices. Our Gluons Shop is special in both its design and its function. Customers can browse and Buy Things Online with us.
