approach to corners 45 deg to grain direction
Results 1 to 2 of 2
Thread: approach to corners 45 deg to grain direction
    Member thisthat's Avatar
    Mar 2020
    Default approach to corners 45 deg to grain direction
    I have parts to cut out (I made a quick diagram attached) and I'm not sure how to approach the corner sticking out at a diagonal to the wood grain direction. I'm cutting in oak right now which is maybe the worst in terms of grain splitting but I also get the problem in walnut.
    It breaks a triangle off the end about 25% of the time.
    I'm climbing milling and slowing down from 140ipm to 35ipm around the corner with an 1/8th inch depth of cut, honestly I'm not sure what else I could try.
    Wondering if anyone has experience with this type of shape.
    Thanks!
    Attached Thumbnails Attached Thumbnails approach to corners 45 deg to grain direction-part-01-png
    Mar 2020
    Default Re: approach to corners 45 deg to grain direction
    So two years later and still having this issue! wondering if anyone might have some thoughts on the matter.
