Ball Nose Upcut vs. Downcut
Results 1 to 5 of 5
Thread: Ball Nose Upcut vs. Downcut
    Jun 2008
    Default Ball Nose Upcut vs. Downcut
    I was about to start doing some 3D cutting and needed some bits. I am seeing that I have options for Up and down cut. As long as I am doing a roughing cut first, does it really matter?
    Member awerby's Avatar
    Apr 2004
    Default Re: Ball Nose Upcut vs. Downcut
    Up-cut is standard, because it evacuates the chips. Down-cut is used when you're cutting plywood or laminates and want to avoid pulling up chips in the top veneer. If you're running a roughing pass first, that's not going to be an issue, so go with the up-cut bits.
    krunkerio's Avatar
    Jan 2022
    Hello. As I know, ball nose spiral end mills are used for smooth contouring and fine detail passes with a CNC router and often for complex shapes like 3D carvings. These bits are also excellent for routing fluted columns and channels in cutting boards and countertops edges.
    krunkerio
    Banned
    Apr 2022
    How I Turned My Hobby Or Passion Into a Successful Business
    martwal167's Avatar
    Mar 2023
    This post is very helpful to me because it gives me a lot of information. I always like to read good writing, and your post had that. Thank you for your help. Fun Games
