Indian carving technique
Results 1 to 4 of 4
Thread: Indian carving technique
    May 2017
    Cameroon
    Default Indian carving technique
    Hi everybody.
    I have a 1200x900 chinese cnc router that works pretty well.
    I intend to make doors and furniture like those on the attached pictures.
    I have the good bits and the right technique. But when I start engraving the gantry and the spindle shake and the line created on the material is distorted. I think that the spindle and the gantry are not strong enough to work on hardwood. What do you think about that ? Can you advise me ?
    Is it a problem of feedrate and spindle speed ???!!!!!? I'm lost.
    Some samples of my works are attached.
    HEEEELP !!
    Attached Thumbnails Attached Thumbnails Indian carving technique-329-jpg   Indian carving technique-633-jpg
    Member awerby's Avatar
    Apr 2004
    Default Re: Indian carving technique
    I doubt that your problems are due to feedrates or spindle speeds. Most likely, your machine just doesn't have the rigidity required to make a good cut in hardwood. When it works "pretty well", what are you cutting?
    May 2017
    Cameroon
    Quote Originally Posted by awerby View Post
    Thanks for your prompt answer. I agree with you that rigidity IS the issue. Anyway I'll try that technique with tender then see if I Can deal with it.
    Member Algirdas's Avatar
    Mar 2009
    United Arab Emirates
    what is static run-out of your spindle?
