Ok to cut manually via jogging (without G-code)
Results 1 to 2 of 2
Thread: Ok to cut manually via jogging (without G-code)
    Jun 2008
    Default Ok to cut manually via jogging (without G-code)
    Hey all -
    I need to clean up the edges of some 4x8 melamine and I am wondering if there is any reason I could not just run a 1/4 or 1/2" compression bit along the edge to do the job as opposed to creating something in VCarve?
    For that matter, what if I wanted to rip a sheet of plywood in half?
    Also trying to avoid buying a track saw...
    Shawn
    Sep 2017
    Default Re: Ok to cut manually via jogging (without G-code)
    Certainly! I do it all the time with both wood and aluminum.
