New to CNC
Results 1 to 9 of 9
Thread: New to CNC
    Dec 2015
    Default New to CNC
    HI I just bought a new "to me" cnc machine and need all the good advice I can get. I have attached pics. It has an ah ha controller with a mach 3 breakout board but no pc or software. my intent is to use it for cutting sheets of ply/mdf for cabinets and furniture. i know nothing about CNC. But I have become comfortable with a few different drafting and cabinet programs that export dxf files. I need recommendations for cam software, tooling, and Ideas for a budget minded vacuum table, and other hold down options. as of now it just has the aluminum table
    Attached Thumbnails Attached Thumbnails New to CNC-img_0901-jpg   New to CNC-img_0894-jpg   New to CNC-img_0902-jpg
    Member routalot's Avatar
    Dec 2003
    Default Re: New to CNC
    You should be in good shape if you already have a good deal of familiarity with some of the software.That said,you till have two new areas in which to develop some further knowledge.Obviously you need to become familiar with getting the machine to carry out your instructions and while you mention Mach 3 specifically,it is a bit dated and other software is likely to work with your breakout board.At some point you are going to have to configure your chosen software to work with the board and you can assign pin functions as you do so,in fact you have to do just that and will be ahead of the game if you have schematics of your hardware.You could take the opportunity to check out Mach 3's newer brother Mach 4 or something like UCCNC.
    As for CAM software,you need to check out the post processor options for each package as you will need something that works with your control software.Many of the packages have trial versions that will allow you to gain some experience before you part with money and you might take a look at a few.Vectric is fairly good and you can find a good number of post processors packaged,they also have a sensible upgrade pathway if you need further capabilities.
    A vacuum system is a very nice thing to have if you have a sufficiently powerful electrical system.You probably know that it needs a high flow rate and the smallest motor I have worked with for holding down 8X4 sheets had a 4Kw motor-it was just about enough.I also have experience with a 14Kw system and it never struggled.Both of these were three phase systems.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Look at Mozaik - Mozaik Software
    And Black Box Vacuums - https://www.blackboxvac.com/
    For a DIY version, look here - https://www.centralvacuummotor.com/shopbot.htm
    You'll need to cut some holes in your aluminum table.
    UCCNC 2017 Screenset
    Dec 2015
    Thanks for the input! I think for now I will stick with Mach 3 just to see if it will mate a little easier, and to see if the ah ha controller and motors even work. I have been considering v-carve pro for the cam software, any thoughts? Also Ive been considering the black box hurricane, any thoughts or criticisms on that system? IF I understand correctly, if my DXF files from my software are good, Mach 3 and V-carve should be all I need to start? Ive used Mozaik in the past, for almost two years. My shop volume is too low to justify the $125 per month, and it wasn't flexible enough without having the big shots rewrite some of the parameters for me. Right now my go to software is Cabinet Planner(awesome for only $90), followed by Sketchup. As you can see it has a portercable 3hp router, so i also need to try to get away with as few tool changes as possible without causing the cycle times per sheet to suffer too much. I hear of some guys using a 5mm bit start to finish, but sounds kinda slow. then other guys say they can push a 1/4" bit a little faster, and I can make shelf holes this diameter, but im worried they may be too big for hardware holes
    Dec 2015
    I should also mention that I want to add a z zero sensor and some sort of pendant with E Stop...
    Dec 2003
    Vcarve will work with your .dxf files.I don't think you need to get too hung up on sheet times as there is more than just cutting to take into account.You have to clean the table between sheets to allow the vacuum to function and you have to locate each new sheet-both these operations take a little time.The better your extraction system is,the less time it takes to clean the table.In terms of how you use the machine,is it the plan to do all the programming in advance so that you can run non-stop or will you be programming during the working day?
  7. #7
    Dec 2015
    I would like to think that everything would be programmed per job, or at least per section of job. Ie box parts, drawer parts, doors ect... would I be doing myself a disservice buying cut2d as opposed to vcarve? to save a few bucks?
  8. #8
    Mar 2003
    Shelby Township
    Does Cut2D support toolpath templates? You're going to want to use those.
  9. #9
    Dec 2003
    Quote Originally Posted by MAHNKEN View Post
    Vectric have a very fair upgrade policy,if you decide to upgrade they just charge you the difference between your original purchase and the next level software.
New to CNC
New to CNC
