Newbie Fuzzy edge while v bit engraving
Results 1 to 11 of 11
Thread: Fuzzy edge while v bit engraving
    Member Snehal_Shah's Avatar
    Feb 2019
    Default Fuzzy edge while v bit engraving
    Hello guys,
    I am having issues while doing V bit engraving in wooden parts on my CNC (a Chinese one).
    Following are the parameters set while machining.
    Feed rate: 200 ipm
    RPM: 5000-6000
    Tool: V bit 30 degree
    Spindle power: 9kW
    Material: Teak wood and birch plywood
    Please refer attached photos that shows a fuzzy top edge. (Birch ply looks awful !)
    Sanding will reduce the burrs but rather it should be machined smoothly.
    I have seen many videos where they get a crisp edge with a V bit !
    I am relatively new to engraving with V bits. I know a DC endmill will resolve the problem but I need sharp corners, that's why I am using a V bit.
    Snehal
    Attached Thumbnails Attached Thumbnails Fuzzy edge while v bit engraving-birch-plywood-jpg   Fuzzy edge while v bit engraving-teak-wood_1-jpg   Fuzzy edge while v bit engraving-teak-wood_2-jpg
    Member CitizenOfDreams's Avatar
    Nov 2012
    Default Re: Fuzzy edge while v bit engraving
    Your chipload seems to be way too high, especially if you have a single edge "half circle" type V-bit. I would try at least 5 times slower, 40ipm@6000rpm.
    Aug 2005
    If the bit is high speed steel and has been used to cut birch ply (baltic birch perhaps) your edge won't last very long regardless of feed or spindle speed. Start with a sharp carbide bit made for cutting wood. I would also slow your feed a bit, but would also increase the spindle speed to something on the order of 15,000 rpm.
    Mar 2003
    Shelby Township
    Lower feedrate, higher RPM, sharper bit.
    I'd go for 75ipm at 14,000 rpm. With a new, SHARP bit.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
    Member machinehop5's Avatar
    Aug 2009
    ...what temperature is your machine room? is the wood frozen? anyone try that yet?
    Nov 2012
    Hmmm... How about cryogenic wood machining? I know they do it with rubber...
  7. #7
    Feb 2019
    Quote Originally Posted by MARV View Post
    My bit is HSS (2 flutes) which seems to be the root cause.
    The chip load with current parameters is 0.017", is it too high? I would surely try out lower feedrate and higher rpm in accordance with all of you.
    Thinking whether the grain structure of "teakwood" has a role in it?
    The machine room ambient temperature is 100 degree F and wood is in normal weather conditions, so its definitely not cryogenic!!
    Thanks for all the inputs, will revert soon with outcome by applying suggested parameters.
    Snehal
  8. #8
    Nov 2012
    Quote Originally Posted by Snehal_Shah View Post
    If it's a "half moon" V-bit, it only has one cutting edge, so it's single flute. 0.017" (0.43mm) is already too high, and if you really have a single flute cutter, then it's 0.86mm - definitely too high.
  9. #9
    Aug 2005
    Teak will eat HSS. Get a new carbide bit.
  10. #10
    Jun 2012
    A coat of finish will also help keep the fuzzies away.
  11. #11
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Hi SS - I use a 50/50 mix of PVA glue to seal the surface before I do fine work. The PVA binds the grain together and it cuts better. You can use other sealers as well that are compatible with the top coat. sharp tools always...plus a rough cut then a finish cut is helpful for grumpy grain...cheers Peter
