No picture showing.It isn't that difficult a task with the right software.Model the pyramid with the correct panel thickness,separate the individual panels with the joint surfaces and generate the program to cut them.You will need a packer beneath the panels when they are being machined or the ball end mill will be cutting some grooves in your table.You may need to machine joint faces one at a time if you need to leave clamping arrangements in place.
