optimizing plywood
Results 1 to 5 of 5
Thread: optimizing plywood
    Default optimizing plywood
    Hi there,
    Hope you're well. I'm using 3/8 inch baltic birch plywood to create dome-shapes. The attached photo was my first test in thicker, cheaper plywood, but you get the idea. Right now I'm using a tapered ballnose with 10% stepover and it's good, but I still have to do sanding before I apply a dye, stain, etc. I'm not doing a roughing pass.
    Is a tapered ballnose best for this operation? Is there anything else I can do to minimize sanding? Or are there any tips on how to best sand a small piece like this?
    many thanks
    stuart
    Attached Thumbnails Attached Thumbnails optimizing plywood-60583544583__a2a56bae-0fba-45f2-9020-0ffd9187452e-jpg
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Default Re: optimizing plywood
    Hi S84 - What is your actual stepover vs a %? To minimise sanding you will need to :
    1) Do a finishing pass with very sharp tool of say <0.5mm stepover
    2) or you can use a form tool such as a 1/2" coving tool and do it in one pass vs many small passes.
    either way very sharp tools are required. For sanding use a sanding sponge not paper and seal the timber with shellac, PVA or a sander sealer before you sand. This will lock up the grain and make sanding much easier.... dye prior to sealing by the way...Cheers Peter
    Hi there,
    Many thanks. Attached is what I did with my tapered ball nose.
    In another forum, a user suggested doing 1/4 ballnose roughing pass, then a 1/8 ballnose finish pass. Any thoughts on that?
    The coving tool suggestion blew my mind-- I hadn't thought of that.
    Same for the sanding sealer... I'm trying to do a row of 8 pendants or so each with different settings so I can take notes and compare.
    thanks again and all the best
    stuart
    Attached Thumbnails Attached Thumbnails optimizing plywood-bit-detail-jpg
    Member Grunblau's Avatar
    Jun 2008
    Michigan, USA
    Interestingly, your best bit bet might be an 'innie' rather than an 'outy.' Have a look at these tools...
    https://www.toolstoday.com/plunging-...uter-bits.html
    You may need to adhere your stock to a spoil board but this approach would likely produce the nicest finish the fastest way.
    Hope this helps!
    Brian
    Aug 2005
    Unless you are doing this for fun, there may be faster ways to do this with manual machines and get a better finish when complete. Because of the opposing grain of the cross plys, it will be difficult to get a clean cut with conventional cutters.
    You may want to consider cutting you blank with a hole saw without the centering drill. CA glue the blank to a wood mandril and take it to a belt sander. No torn grain from the cutter (which is clearly visible in your photo), and a much smoother finish after different grades of abrasive. Many folks that do manual wood turning take it a step further and apply stain and then CA glue for finish while still on the lathe. Part off and you're done.
optimizing plywood
optimizing plywood
