Yes, it's normal.
Surface both sides.
Hello,
I have a CNC machine with a vacuum table of 120x250cm. I use MDF 10mm or 15mm, when I surface the sheet to get a flat surface the MDF sheet curvas outwards. Is this normal? what am I doing wrong?
Yes, it's normal.
Surface both sides.
UCCNC 2017 Screenset
Thanks Gerry, will try.
once you surface it a couple times it happens as well. I find that once it starts to curl on the corners surface it and then flip it over and use the other side and its good for a little while again. that's on a 4'x8' mdf sheet
