Do you have the entire pdf that those pics came from, there are about 30-40 in there?
As the Title says, I am looking for different Joints for either my Laser Cutter or CNC Router. I found these so far but guess there must be a lot more free joints out there?
I had a shot at the dovetail ones there great but if you are just a tiny bit out you can't fix it because it is an exact fit ,so no sanding a bit off you then create a gap .I was working on going over the end of the table to create a standard dovetail might be easier with finger jointing as well.
