Roboform 400
Results 1 to 3 of 3
Thread: Roboform 400
    Jun 2003
    Phoenix, AZ
    Default Roboform 400
    I have a Roboform 400 that keeps shutting down with an E909 error (Main Voltage too low). The voltage to the step up transformer and the voltage out of the transformer are good but machine continues to shut down at random and keeps giving me an E909 error. Any Suggestions?
    Member mdynac's Avatar
    Jan 2006
    for whatever reason, charmilles decided to measure the value of the 80 volt dc "well" voltage to monitor "mains too low" so if you get that error, you need to change (or at least check) the K2 (i think) relay....it comes on when the cutting section comes on.....
    this relay supplies the raw ac voltage to the rectifiers which generate the 80 vdc cutting voltage, this circuit is unregulated, so you get a "mains too low" error if the 80 vdc is too low......go figure.....
    it seems the contacts on the relay get arc'ed so they start to drop voltage after years of use....
    hellava way to check the AC mains supply......
    it seems that charmilles is only interested in "mains too low" only when the cutting section is fired up.....
    i believe this is done to keep technology in spec.....
    good luck,
    michael
    Registered Linux User #348337
    EMC2 Rocks!!!!
    Mar 2013
    Costa rica
    Default Re: Roboform 400
    Quote Originally Posted by bocko912 View Post
    Hello, hope you are doing well, I have a roboform 22 and i am having the same issue but the program wont even start, I just hit he cycle start and then I get this alarm.
    did you solve your problem?
Roboform 400
Roboform 400
