Omax Waterjet startup
Results 1 to 13 of 13
Thread: Omax Waterjet startup
    Member Karl_T's Avatar
    Mar 2004
    Dassel.MN
    Default Omax Waterjet startup
    My son recently bought a used Omax 55100 waterjet at auction.
    I had a thread about getting him a 240 to 480 transformer with some background info. https://www.hobby-machinist.com/thre...sformer.99660/
    Went to my son's place to check out the transformer. we got it running a 440 volt 3 phase motor, all looks great here. He's all set to permanently wire it in to the waterjet.
    Spent most of the time looking over the machine and especially the control.
    The control is a PC based stepper controller. it has a proprietary USB control box. This device then feeds proprietary driver cards that converts steps to DC servo drive. The servos are tiny by CNC standards. the control just has a few outputs from the USB control box. Looks like this box also has just a few inputs - servo fault being the most important one. the whole thing looks a lot like a Mach 3 stepper control.
    Did a bit of power wire tracing. It looks like the PC, servos, etc. all take 120 VAC power from a 480 to 120 transformer. It sure looks to me like the kid can buy a PC, install the software. then remove these two wires and connect to a wall outlet. I think he will be able to jog the machine around at this point. Does anyone know for sure???
    OK, his job for the week is install all power wiring, get a PC and install software.
    My job is read all the manuals and try to learn all I can about starting up a water jet.
    By chance, if anyone out there is expert on this machine, I'd sure like to hear from you. Neither of us have done more than just watch one run.
    Member neil76's Avatar
    Jan 2020
    Default Re: Omax Waterjet startup
    Hi There Karl
    This will run on a windows based PC but the system you have is called the 5 axis USB controller, this will only run on a 32Bit operating system.
    the two cables from PC the black box power the axis controller, this Omax part number 305772.
    Feel free to PM for more info.
    Thanks.
    Mar 2004
    Dassel.MN
    Thanks for your reply. I am SURE to have many questions once we get a PC up and running.
    Jan 2020
    Hi Karl
    No problem, if you send me your email address via the private message I can send you over the the relevant schematic/ information on the USB power supply.
    Mar 2004
    Dassel.MN
    Thank you so much for the very kind offer. I just PMed my email.
    Karl
    Mar 2004
    Dassel.MN
    Just for the record here, Neil has been EXTREMELY helpful by email. he really knows these machines.
    My son will be installing power supplies for the USB controller and getting a PC all set up this week. Hope to jog the machine soon.
  7. #7
    Mar 2004
    Dassel.MN
    Say would somebody please double check me here?
    The molex connector to the USB controller is an obsolete four pin style. We checked around and none of our running computers have one of these. These were used in every computer back in the IDE hard drive days. I am almost sure the red wire is +5 volt, the yellow +12 volt, and the two blacks are common. But the cost of a mistake is HUGE.
    The pic is of the connector to the USB controller in the waterjet. We are installing two new power supplies to run this USB controller.Omax Waterjet startup-molex-jpg
  8. #8
    Dec 2013
    Check for sure with a volt meter, but yes, red=+5V, yellow = +12V, and black = common
    Jim Dawson
    Sandy, Oregon, USA
  9. #9
    Mar 2004
    Dassel.MN
    Its breathing!!!
    Just need to add water and garnet
    Omax Waterjet startup-screen-shot-2-jpg
  10. #10
    Mar 2004
    Dassel.MN
    Here is part 1. just a piece of scrap metal laying around the shop.
    SPECIAL THANKS TO NEIL76!!!!
    He is a pro on these machines and was incredibly helpful.Omax Waterjet startup-part-1-jpg
  11. #11
    Dec 2013
    That's awesome! Wish you were closer to me, could have given you some work a few days ago.
    Jim Dawson
    Sandy, Oregon, USA
  12. #12
    Jan 2020
    Thanks Brother
    Happy Machining
  13. #13
    Sorry to hijack this post but wasn't sure how to reach out to Neail separately....would you mind emailing me as well? I'm working on a 1999 model 2652 with a 2040 pump and having some issues I believe with the wiring and can't seem to track down a schematic for the communication cable. Thanks Bill taylorspecialties@gmail.com
