Does anyone have experience with Wardjet? I am looking at purchasing a new E1530 with a 50hp Hypertherm pump and 5 axis. From what little I have seen, I can't see the extra 60k+ to go Omax Maxiem or a Flow Mach 200. My main material this is for is .375" and .5" brass.
Nice to meet you here. I am Vera from Shenyang HEAD Science and Technology Corporation, which is a professional waterjet cutting machine manufacturer.
Not all situations are suitable for using a waterjet cutting machine, so what is your situation ? More than 12 years'service at customers gives us enough experience to share with you. We are happy to provide you with advice refer to cutting solutions so that help you improve your productivity.
In order to give you a good recommendation, would you kindly fill in your cutting requirements below:
1. What materials do you want to cut?:_____
2. What is your materials sheet length, width and thickness?: _____
3. What cutting production capacity do you want?:_____
4. What cutting method are you using at present?:_____
5. You can send your other contact method you want :
Looking forward to your reply.
Thank you so much.
Best regards!
Vera
