Hmm, an interesting problem. I once had something similar, I spent a lot of time and effort to fix this failure. I once spoke to a friend of mine, he is a Level 2 Electrician Penrith . He checked the grounding and the power distributor. He was able to repair my car. I mean, you can't solve the problem alone. It is better to entrust the case to a professional and everything will be fine. I also advise you to trust only reliable masters, because it is not uncommon that they intentionally damage cars so that you return to them and pay money again. good luck and bye. I hope I was able to help you with your problem and it will not bother you
