I need help. I bought an Eagle Plasma 4x4 cnc table to use with my Hypertherm Powermax 380. I have everything build and set up with the torch wire in the machine spliced and connected to the relay terminals on the control box... but when I try to run a g-code the torch does not turn on. I have the ground attached to the metal, the air is sufficient, and the amperage is set correctly. According to my Mach 3 program, the torch should be on but it isn't cutting. If anyone has any ideas that could help me out, I would be very grateful. I've had the table for a good month now and haven't been able to use it yet.
