Haven’t try not using the dynamicAfter you have loaded your drawing to be ran, you have the option you can turn dynamic on or off.....
Run your program both ways and check your results.
Also what's the thickness of material that you are cutting, Dynamic should not be used on thin material, the system tries to make to many adjustments far too quick.
But I will that shot
So how often do you guys change the mixing tube?
