Pump help
Results 1 to 2 of 2
Thread: Pump help
    Dec 2003
    Default Pump help
    Hi I have a Flow pump with mechanical shifting , it intermittently stops shifting.
    On the hydraulic shift tubes one side gets hot the other is much cooler
    if some one has a flow pump can they please advise are the tubes hot or cold , this way i can work out which side is faulty
    peter
    Jun 2010
    Default Re: Pump help
    Those shift tubes and springs need to be replaced, they can get worn out and that can cause erratic shifting.
Pump help
Pump help
