agie 120 hard disk problem - Page 4
Page 4 of 4 FirstFirst 1234
Results 61 to 80 of 80
Thread: agie 120 hard disk problem
  1. #61
    Nov 2008
    Argentina
    Default Re: agie 120 hard disk problem
    Hi tintin,
    I have all the installation disks, FW13.02. Please send me your email trough pm and I share you the dropbox link.
  2. #62
    Sep 2016
    Belgium
    Hello.
    Have you managed to repair your Agie machine?
    regards
  3. #63
    *Registered User* sdm83's Avatar
    Sep 2018
    Does anybody has the image of the agiecut 250FS?
  4. #64
    Member turbina's Avatar
    Apr 2006
    Italy
    Thanks to your indications I have restored a CUT220, now I just have to set the correct language,
    I have seen that in C: \ CU91 \ CU91MES.MES there is the language of the buttons, labels and messages,
    there are 5 languages:
    ENGLISH
    DEUTSCH
    RUSSIAN
    FRANCAIS
    ITALIAN
    how do you set the language?
    thank you very much
  5. #65
    Nov 2008
    Argentina
    Hi, turbina,
    that's an easy one. If the machine starts normally, at the very first screen that appears, just press "Esc" key. Then it will direct you to a "Main menu" screen, where, if I remember properly, F1 key is "Configuration pages". There is the option to change the language.
    Regards
  6. #66
    Apr 2006
    Italy
    Done, thanks for your quick help !!!
  7. #67
    mattmurray's Avatar
    Jan 2020
    Does anyone have a disc image for Agie Sprint 20? My hard drive died and we have no image backups of it. Trying to replace the hard drive but have no O.S. to copy over. Please help!
  8. #68
    Member semihbayar's Avatar
    Jun 2018
    Hi Ironman.Anzus,
    Could you please share with me your installation disks for FW13.02 ?
  9. #69
    Member fullerjl's Avatar
    Jul 2021
    Thank you for the in depth instructions. The problem I am having is connecting an external ps2 keyboard to the agie 120 edm, so I can save the changed bios setting. the bios shows F10 to save it. The keyboard on the CF does not have an F10, so I will have to the ps2 keyboard. I plugged the ps2 keyboard into the board in side the cabinet and rebooted but the machine did not see it. I am stuck, any help will be greatly appreciated.
    Thank you
  10. #70
    Member Algirdas's Avatar
    Mar 2009
    United Arab Emirates
    is the keyboard powered on boot? check jumpers on the mainboard.
  11. #71
    Jul 2021
    Thanks for the quick response. The keyboard light come on for a second and then off when I first boot up. I only have a operator not a service manual so I do not know which jumper on the board to check. I will send 2 pictures on the board with the ps2 connection. If you know which jumpers to change please let me know.
    Thank You
    Attached Thumbnails Attached Thumbnails agie 120 hard disk problem-img_1258-jpg   agie 120 hard disk problem-img_1259-jpg
  12. #72
    Mar 2009
    oh, that's Siemens industrial computer. Congratulations ! - general knowledge of motherbords is useless.
    On the other hand, there is high probability to find good data sheet by model name.
    On the third hand, a regular PS2 keyboard could be incompatible.
    On the last hand, all necessary setting combinations could be achieved via jumpers at that jumper field.
  13. #73
    Jul 2021
    Yes I tried doing a search on the internet for KSP-M45-R66 and all that came up was the board selling on e-bay. I will continue searching on the internet again hoping for the best. If you happen to come across the data sheet or find that the ps2 keyboard is not compatible, please let me know. If anyone else has any other ideas i would appreciate knowing.
    Thanks again for the quick response and ideas to check out!
  14. #74
    Mar 2009
    check if there is "tab" on that keyboard
    manys systems support cycling through options with "tab" key.
  15. #75
    Jul 2021
    I tried using the TAB key when booting and in the bios but unfortunately it did not work. Thanks for the idea, it is appreciated. I am willing to try any ideas anyone has.
    Thanks You Again
  16. #76
    Member 43pO's Avatar
    May 2011
    Hamburg
    Hello, I would like to know at what point I need the "Final config" disk. yks said that this disk is a must for rebuilding a drive, but I can't find any indication in his manual at what point the "Final config" disk is needed. Maybe the master himself can tell you or someone else?
    Thank You
  17. #77
    May 2016
    Ukraine
    Quote Originally Posted by 43pO View Post
    Thank You
    As i remember the system itself will promp you on a screen to insert the "Final config" disk.
    Of course only if the sequence of your previous actions was correct.
  18. #78
    May 2011
    Hamburg
    Thank You very much, yks!
  19. #79
    Partin_Csaba's Avatar
    Mar 2022
    Good day.
    Thank you for taking the time to read this.
    We have an AGIE 250Hss that no longer takes axis reference
    (axis do not move at all) point and gives the following errors:
    No connection to host.
    Check, if computers are powered and connected.
    In the red field it writes L_ and in the grey field next to that Line down.
    Additionally the motor where the wire spool sits keeps spinning counter clockwise when it should not.
    We have a donor machine and have replaced everything in the CF control cabinet (entire backplate with all pcbs inserted) and also the WID4 board on the machine itself.
    The HDD was also changed with the one from the donor machine.
    After changing everything :
    The motor where the wire spool sits keeps spinning counter clockwise when it should not.
    The machine axis do not move.
    No connection to host.+ Check, if computers are powered and connected. errors disappear
    With this donor HDD the machine also has problems booting.
    It gets stuck on autoexec.bat 9 out of 10 times. (on the 10th it boots)
    We came to the conclusion possibly both HDDs are bad/partially corrupted.
    We put everything back to the original state. (we put back the backplate together with the original HDD)
    Would copying the original final config disk (we have it) help?
    If so how can we do it without reinstalling everything.
    Thank you again.
  20. #80
    Member Manuel215's Avatar
    Nov 2022
    Hello. i would also need this information for the jumpers for the ps2 connection. Many Thanks
