Need Help! Chinese Breakout Boards
Page 1 of 2 12 LastLast
Results 1 to 12 of 17
Thread: Chinese Breakout Boards
    Registered GrahamIT's Avatar
    Jun 2004
    United Kingdom
    Default Chinese Breakout Boards
    Hello everyone,
    Just a quick question, has anyone had experience of this cheap breakout board please?
    CNC 5 Axis Breakout Board interface for Stepper Motor Driver Mill/Input Power:5V | eBay
    I'm an electronics engineer and was thinking of making a taylormade board myself, but at this price it's hardly worth the effort.
    Eventually I'll upgrade to an ESS Smooth Stepper and 3 of these, but for initial playing around I thought this would be a start at least. I've got 3 Geckodrives for my steppers already.
    Graham
    Jan 2005
    I have one of those on my mill drill and it has worked just fine for me.
    Member john-100's Avatar
    Mar 2007
    uk
    Hi Graham ,
    the breakout boards do work but like the tb6560 boards they do break a few design rules
    not connecting a +5V supply to pin 14 of one of the 74HC14 IC's
    or not connecting the unused input pin 13 to 0V or +5V - OK for a 7414 but not the CMOS version !!!!
    the 1K resistors connecting the 74HC244 output to the boards enable output terinals could be a problem with some stepper drivers
    John
    Attached Thumbnails Attached Thumbnails Chinese Breakout Boards-cnc-5-axis-bob-jpg
    Jun 2004
    United Kingdom
    Quote Originally Posted by john_100 View Post
    Hi Graham ,
    John
    Thanks Guys.. John in particular that's very helpful, thanks. Nothing there that can't be fixed easily, so all in all a good buy at under £10.00
    Mar 2007
    uk
    Hi Graham ,
    the circuit notes are my attempt to fill in some of the details missing from the breakout boards manual ,eg the signals on the 9 , 11 and 13 pin connectors
    John
    PS on the board there is a resistor thats only connected to one terminal ! -
    its one of the seven resistors that I removed from between the two 74HC244 IS's in the picture
    Attached Thumbnails Attached Thumbnails Chinese Breakout Boards-5-axis-bob-errors-jpg
    Jun 2004
    United Kingdom
    Hi Graham ,
    John
    I wonder why they connected dir X to both pins 14 and 17?
  7. #7
    Mar 2007
    uk
    Hi Graham ,
    its my error
    when I've copied from an earlier diagram used in post 9 in this thread :-
    http://www.cnczone.com/forums/genera...out_board.html
    I've typed X dir for pin 17 instead of B dir !!
    John
  8. #8
    Registered alcor's Avatar
    Feb 2013
    france
    Hello,
    I'm not electronics engineer and CNC hobbyist beginner, I'd like to get your advices :
    Is this breakout board only able to work with opened circuit limit switches ?
    (Is there any workaround to work with closed circuit ?)
    Is this breakout board never "resetting" DB25 state after a limit is reached ?
    My card is rising state on all input pins - 10,11,12,13,15 - when only one limit is reached and did not release state after limit switch is released.
    (Is there any workaround to reset state automatically ? i'd like to use one switch to probe surface).
    thanks
  9. #9
    Mar 2007
    uk
    Hi alcor
    are your limit switches mechanical switches or electronic switches ?
    more details of the switch will help
    assuming you are connecting all the limit switches to one breakout board input
    if they are mechanical switches
    you can wire normally closed in series and connected to one breakout board input
    the printer port input can only detect when all switches are closed or when the first switch opens
    with normally open switches you can wire them in parallel
    then printer port input will only detect when all switches are open or when a switch closes
    using one input your control software will not know which switch has been operated if more than one axis is moving
    if you have normally closed HALL switches (or other proximity detector)
    you will have to connect one switch to one input on the breakout board
    unless you add some extra circuit
    John
  10. #10
    Feb 2013
    france
    Thanks John,
    I used common mechanical lever micro switches. I have two normally closed switches in serie per axis at end limits. I have 3 axis so i used 3 breakout board inputs with 1 common ground. I will use another mechanical switch probe connected to A-LIM input for surface probe.
    I tested the 3 loops independently (not connected to the breakout board) they reacted as expected.
    I'd tested 2 cases :
    1/ X Y Z loops are connected as mentionned in attached scheme, A-LIM loop is not present. As soon as i power on the board (Note : i use USB 5V plug to power the board), DB25 voltage on pins 10, 11, 12 are set to 5V. (i didn't tested pin 13). Opening any switch doesn't change anything.
    2/ I unplugged X Y Z loops but the common ground is always present on the breakout board GND inputs XYZ. I opened A-LIM switch and then power on.
    pins 10, 11, 12 and 13 are 0V. As soon as i closed A-LIM switch, all 4 pins are set to 5V.
    Explaining this, I realize that I have not tested if the // cable is involved in the problem ... I'll check this as soon as i can.
    Otherwise do i need diode on GND ?
    Attached Thumbnails Attached Thumbnails Chinese Breakout Boards-5axis-bob-ls-png
  11. #11
    Mar 2007
    uk
    Hi alcor
    your connection diagram looks correct
    going by the photos of the 5 axis B.O.B. on sale
    it looks like there is 2 versions
    the version I have tested had no +5V supply to pin 14 of the 74HC14 used in the circuits connecting the E Stop and Limit switches to the PC printer port
    without a +5V supply to pin 14 the 74HC14
    the E Stop and limit switch circuits depend on power from the printer port
    and may not all ways give you valid logic levels
    to fix the problem I added the link shown in yellow in the first picture below
    with the +5V link added the IC will be powered by your 5V supply
    without the board being connected to the computer
    you should find when the E stop switch or limit switch is closed
    the corresponding printer port pin will be at a logic 1 ( +3V to +5V)
    when a switch opens the corresponding printer port pin 10, 11, 12, 13 or 15will be at a logic 0 (0V to 0.8V )
    John
    Attached Thumbnails Attached Thumbnails Chinese Breakout Boards-viewpicture3-jpg   Chinese Breakout Boards-5-axis-bob2-jpg   Chinese Breakout Boards-ttl-logic-levels-jpg
  12. #12
    Feb 2013
    france
    Thanks for your precious help john.
    I checked the parallel cable and all possible ground loops. Nothing to mention.
    I added the link on my board and now i have the power led turned on when i plug parallel port on my computer, before 5V USB powered on.
    After several attempts, I still noticed that the behavior of the card is as follows (L/S input states) :
    1. If all inputs XYZA-LIM & E-STOP are open : Pins 10, 11, 12, 13 and 15 are 2.58 V.
    1. If at least one entry XYZA-LIM & E-STOP is closed : Pins 10, 11, 12, 13 and 15 at 5.16 V.
    However, i noticed that the behavior is not the same when probing the // port with a voltage meter or computer // port sniffer :
    - when using a sniffer : the // port is plugged to the PC and the B.O.B. is not releasing the state when going from state 2 to 1 (see list above),
    - when using a voltage meter : the // port is unplugged and i mesure voltage on the connector pins. The board does return to logic 0 when going from state 2 to 1.
    I probably have de defective break out board - or a bad designed board, don't you think ? :-)
