- lighted acrylic signs
has anyone attempted these with cut2d and an end mill bit?
Re: lighted acrylic signs
don't have a drawing, was just curious since i don't have vcarve. what would be a good cut depth?
to begin, never more depth than diameter .004 feed per tooth. rpm according to surface feet per minute.
I use a diamond drag for anything that will be seen from at least a few feet away. .02 step over cross hatch pattern it works quite well for the signs I make
- You may not post replies
- You may not edit your posts
Forum Rules
