Need Help! Sign Foam
Results 1 to 3 of 3
Thread: Sign Foam
    Registered gene8522's Avatar
    Oct 2010
    Default Sign Foam
    I'm making a monogram 23" circle and I need help finding 3/4" sign foam or ridged foam to cut it. Could anyone please tell me what you use, what name do I look for and if your in the Houston area where do you buy the foam. What I have found on-line they want as much for shipping as the foam.
    Thanks for the help.
    Member awerby's Avatar
    Apr 2004
    Default Re: Sign Foam
    Try these guys:
    Reece Supply Co
    2606 Bell
    Houston, TX 77003
    800-776-0113
    713-228-9496
    Apr 2014
    Old thread anyhoo I found this hard foam today with a solid skin on both sides called Nema strangely enough, cuts really well fire retardant and ranges from 12 to 25 mm thick starts at $100 au for a 2400 x 1200 sheet Interesting .
    Sign Foam-nema-jpg
Sign Foam
Sign Foam
